I've been suffering from input lag and micro stutter issues for months. Problems even persist in desktop and chrome, for instance, when I move mouse cursor around on the desktop and scroll through a page in chrome. It is not an internet issue nor it is display related, since when I connect my laptop to the monitor it feels much smoother and I don't experience any input lag. I decided to run latencymon to determine the cause of the issues after seeing some users recommending it in other threads. And here is the result.
At the time I tested, I was playing VALORANT (multiplayer) and no other programs were running except for discord.
Does the result look OK or bad? If it's bad, what could I do to reduce latency?
What will a fine PC's latencymon result look like?
Re: What will a fine PC's latencymon result look like?
I remember getting different results when I tried latenmon in my pc, I’m not sure if it’s affective at this
Turn off hardware acceleration on discord or close it altogether then try again. I had the same issue when I played valorant with my friends in the shroud discord server but now we just use in-game voice chats.
and on browser settings too.JakeGilnder wrote: ↑26 Aug 2022, 20:43Turn off hardware acceleration on discord or close it altogether then try again.
why not? unless you have a laptop with exact specifications as your pc ¯\_(ツ)_/¯ just looking at the nvidia's graphics alone got two separate versions for notebooks and desktopsIt is not an internet issue nor it is display related
but you need windows reinstall. remake the windows install from the microsoft's tool and reinstall
Most adults need 7-8 hours of sleep each night. - US FDA
This is one of my best LatencyMon results, if you have a better result, tell me how you did it.
- latmon good result.PNG (95.26 KiB) Viewed 4821 times
- ftghftyhhgy.PNG (143.58 KiB) Viewed 4821 times
- ertghegtrertg.PNG (99.87 KiB) Viewed 4821 times
This is from windows 10
- 2023-07-18_20_20_48-Window.png (34.37 KiB) Viewed 4966 times
Please tell me if you got better stats in >= 1min of test
Note: I didn't disable drivers/close background apps for the test.
I look for best averages and I'm very curious to know if/how someone got a lower average interrupt to process/DPC latency than I do and how they managed to get those.
- My test.png (732.87 KiB) Viewed 4820 times
There are very good indeed, what guide did you follow to achieve these ?jc008titan wrote: ↑07 Sep 2023, 14:30Please tell me if you got better stats in >= 1min of test
I mostly used Calypto latency guide for the results(big impact), but I used a lot of different tweaks I learned in the past 5 years from varius sources(some of them were: EverythingTech, Fr33thy, World of PC).
I'll make a list of apps i used to optimize my pc(some may be placebo, but it works in the end*):
winaero tweaker(big impact), iobit uninstaller, ccleaner(first 3 uninstalled after use), quickcpu(run once when pc starts), cpu core parking, parkcontrol, process lasso(i think this is the best app out there), mem reduct, rtss, msi afterburner, islc, timer resolution(last 7 are running in the background at all times), morepowertool, DDU, moreclocktool(those last 3 for gpu tweaks), interrupt affinity policy tool(very important when balancing cpu usage on the cores(at affinities, select everything except core 0 on usb, gpu, network and sound)), msi util v2, autoruns(disable useless background tasks).
It takes me about an hour to do all the tweaks(got used to it after having to do it so often).
I can get most computers/laptops to run in under 2.5us average interrupt to process latency and under 1us average interrupt to dpc latency using the above apps.
I am willing to learn about more tweaks to get my pc to have an even lower interrupt latency.
