I have already tried as mentioned in the previous answers. I did a clean install of Windows 11, it was the same. Then I went back to Windows 10 - still the same.TheKelz wrote: ↑11 Dec 2023, 10:18Then try doing a clean Windows reinstall.anarhistabg wrote: ↑11 Dec 2023, 06:06No, I don't use such programs.TheKelz wrote: ↑11 Dec 2023, 05:12Do you run any RGB program in the background (NZXT cam; corsair or g.skill and etc)?anarhistabg wrote: ↑10 Dec 2023, 20:08
1. I never OC the CPU. I have always used both the card and the processor at stock frequencies.
2. This is one of the many things I have tried so far - no change.
3. This has also been tested - no change. The stutters are there.
Fun fact: I tried all possible tests and benchmark tests on the video card, memory, processor, SSD drives, etc. Everything goes without problems or errors.
HUGE STUTTERS in every game...
Re: HUGE STUTTERS in every game...
try threaded optimization off in NV control panel. helped me a little, not perfect though.
Did you try Nvidia driver version 537.58?
Im using the latest drivers: 546.31 , I've tried many different drivers, none of them make a difference.
537.58 is the last driver that doesn't have stutters. If you check Nvidia subreddit on Reddit, you will quickly find out that most people are affected by this and every driver after 537.58 has been stuttery. I can attest to this because I recently decided to try the newest one and it was a stuttery mess. Went back to 537.58 but still had stutters. Ended up reinstalling Windows and THEN installing 537.58 again because even DDU didn't solve the issue.anarhistabg wrote: ↑12 Dec 2023, 18:38Im using the latest drivers: 546.31 , I've tried many different drivers, none of them make a difference.
Can you run Prime95 (small FTTs) and Ycruncher without trottle? Use HWInfo to check if the effective clock is the highest one and that there is no throttle reason.
