MSI Z790 d4 bios guide
Lev1n
Re: MSI Z790 d4 bios guide
Post by Lev1n » 03 Mar 2024, 04:57
Slender wrote:
01 Mar 2024, 12:06
Lev1n wrote:
01 Mar 2024, 12:02
Do you only change oc tab? What about other tabs?
another like on first message.
Just copy everysettings you done. Games are randomly alt f4. I think my cpu or mobo is brick cant handle those settings :D
Post by Slender » 03 Mar 2024, 08:41
Lev1n wrote:
03 Mar 2024, 04:57
Slender wrote:
01 Mar 2024, 12:06
Lev1n wrote:
01 Mar 2024, 12:02
some wrong settings, idk, do you stress tested your pc? RAM xmp / manual ? 1t / 2t ? cpu switch freq need 500 to stable. Msi lite mode? need always 1/1 or lite mode 1. CPU voltage override only and set stable voltage.
what your cpu? You can find you max turboboost freq (for my 13700kf is 5.3) and set it with auto voltage, another settings same.
for me 5.3 have 1.2v with auto.
Lev1n
Post by Lev1n » 07 Mar 2024, 02:11
Slender wrote:
03 Mar 2024, 08:41
Lev1n wrote:
03 Mar 2024, 04:57
Slender wrote:
01 Mar 2024, 12:06
Lev1n wrote:
01 Mar 2024, 12:02
I couldnt find the best settings and i feel lazy nowadays. I just turn off e cores, Turn on xmp(gear1) put cpu to 5.5 ghz 1.350 voltage. Games are good for 1 day the next day everything is off the next day they are hella smooth. Dont know what im gonna do :D
Post by Slender » 07 Mar 2024, 06:40
Lev1n wrote:
07 Mar 2024, 02:11
Slender wrote:
03 Mar 2024, 08:41
Lev1n wrote:
03 Mar 2024, 04:57
Slender wrote:
01 Mar 2024, 12:06
turnoff ecores into bios is bad
Lev1n
Post by Lev1n » 07 Mar 2024, 07:51
Slender wrote:
07 Mar 2024, 06:40
Lev1n wrote:
07 Mar 2024, 02:11
Slender wrote:
03 Mar 2024, 08:41
Lev1n wrote:
03 Mar 2024, 04:57
Why turning them off is bad?
R1sk
Post by R1sk » 07 Mar 2024, 08:56
[/quote]
[/quote]
[/quote]
because all curves are based on VID
13th gen 14th gen cpus are fully load balanced and voltages are VID priority assigned . VID contains E-Cores too..
Post by Slender » 07 Mar 2024, 22:01
R1sk wrote:
07 Mar 2024, 08:56
[/quote]
[/quote]
[/quote]
yeah, bro, thanks for info.
also, disabled bios cause bad lat.moon results and high dpc/isr latency.
