Everything about latency. Tips, testing methods, mouse lag, display lag, game engine lag, network lag, whole input lag chain, VSYNC OFF vs VSYNC ON, and more!
Input Lag Articles on Blur Busters.
Post
by Slender » 08 Feb 2024, 04:05
copy and apply that script in powershell
Code: Select all
Get-CimInstance -ClassName MSPower_DeviceEnable -Namespace root/WMI |
Set-CimInstance -Property @{Enable = $false}
xShino
Post
by xShino » 08 Feb 2024, 05:50
So I guess this disables "Allow the computer to turn off this device to save power" in device manager.
But is it really good to disable ALL energy saving? Even components, that you are not really using? IMEI for instance also has this option.
Post
by Slender » 08 Feb 2024, 09:19
xShino wrote: ↑08 Feb 2024, 05:50
yes, it is.
gaming pc not need any chipset or intel me drivers, perfect is clean install (only nic and gpu driver)
xShino
Post
by xShino » 08 Feb 2024, 09:39
So you are telling me, that you don't have "Intel Management Engine Interface" in your Device Manager under "System Devices"?
(Only Intel CPUs might have this though)
You don't have to manually install drivers, for them to be in there, you know.
Post
by Slender » 08 Feb 2024, 11:14
xShino wrote: ↑08 Feb 2024, 09:39
yes, i dont have it.
eropsy
Post
by eropsy » 09 Feb 2024, 04:49
Slender wrote: ↑08 Feb 2024, 11:14
but you have exclamation mark in device manager if you dont install chipset drivers for intel board
Post
by Slender » 09 Feb 2024, 05:01
eropsy wrote: ↑09 Feb 2024, 04:49
eropsy
Post
by eropsy » 09 Feb 2024, 06:28
Slender wrote: ↑09 Feb 2024, 05:01
mb wrong read. another question is, if you have intel board, how you dont have 'intel me' in device manager
Post
by Slender » 09 Feb 2024, 06:29
eropsy wrote: ↑09 Feb 2024, 06:28
because i dont have any chipset, bro
eropsy
Post
by eropsy » 09 Feb 2024, 06:32
Slender wrote: ↑09 Feb 2024, 06:29
how?
