USB port question mouse/keyboard.
7800x3d
Post by 7800x3d » 19 Mar 2024, 07:49
Hello from my name you can probably tell i've got a Ryzen 7800X3D paired with a B650 Aorus Elite AX rev 1.2
Now my initial question is i've got a Wooting 60HE + Logi x superlight and wanna make sure to correctly put the mouse and keyboard in the correct slots for the best speeds/less latency possible, does it matter to where i put my USB's? - Should i divide them in different slots? - should i put them next to each other? - these are some question i've got, also should i enable/disable xHCI and USB Legacy support in BIOS - need some real answers picture down below is the motherboard i got if someone could maybe point out which slot i could use for what, it would be huge if somebody with knowledge could learn me the ways when it comes to propperly putting mouse/keyboard in correct slots.
