kernel tweaks, updated May 16
Re: kernel tweaks, updated May 6
I'd love to see some explanation of what these tweaks even do. There is IoQueue, ProtectionMode, DpcWatchdog... like what do they do?
Re: kernel tweaks, updated May 3
Hi, where are the values from the 30th of April update? Those worked best for me. CheersHyote wrote: ↑06 May 2024, 12:42You can add them as many times as you like, only the values will change. I changed most, so you can even compare them with your current registry values.
Unfortunately I have no idea. CacheAwareScheduling was probably on 3 instead of 1, BufferSize 32, IRQ8Priority 1, DpcTimeout, DpcWatchdogPeriod, DpcWatchdogProfileOffset, these 3 were at 120000, PriorityControl was something else.bleya99 wrote: ↑07 May 2024, 06:43Hi, where are the values from the 30th of April update? Those worked best for me. CheersHyote wrote: ↑06 May 2024, 12:42You can add them as many times as you like, only the values will change. I changed most, so you can even compare them with your current registry values.
I see, I appreciate it nonetheless!Hyote wrote: ↑07 May 2024, 09:10Unfortunately I have no idea. CacheAwareScheduling was probably on 3 instead of 1, BufferSize 32, IRQ8Priority 1, DpcTimeout, DpcWatchdogPeriod, DpcWatchdogProfileOffset, these 3 were at 120000, PriorityControl was something else.bleya99 wrote: ↑07 May 2024, 06:43Hi, where are the values from the 30th of April update? Those worked best for me. Cheers
Re: kernel tweaks, updated May 8 (completely rewritten)
Feedback time for some of the added tweaks (disclaimer: I'm mainly focusing on input delay and feel).
HypervisorEnforcedCodeIntegrity - Enabled - 0 = increases my input delay.
"SizeReqBuf" 95268 = a bit smoother but with minute increase in input delay I prefer to run without this one.
deleting : PagedPoolQouta & NonPagedPoolQouta = increased my input delay by a lot (I set mine to 0) *I think you also removed these tweaks*
"SystemResponsiveness" - dword:00000064 = increased my input delay (I have better input with this to 0)
for DirectX and DXGKrnl tweaks, I have been running the same tweaks even before, we chose the same ones to add lol.
for Power tweaks, input delay is a bit better but I'm still evaluating, overall pretty nice
Are you thinking there's a problem with the Windows operating system? I can offer free advice - you could consider using Linux or macOS instead.
I'm changing them up a lot currently but what you suggested is nice. HypervisorEnforcedCodeIntegrity 0 really does increase input lag and also I messed up SizeReqBuf, it should be 4410 hex. Removing PagedPoolQuota and NonPagedPoolQuota is also just plain bad I admit it. SystemResponsiveness is a weird one because at 100 it disables MMCSS as far as I know. Right now I'm using 0 as well for it, so our settings match.joolae wrote: ↑09 May 2024, 04:53Feedback time for some of the added tweaks (disclaimer: I'm mainly focusing on input delay and feel).
Hey, I can't see these registry PagedPoolQouta & NonPagedPoolQouta.joolae wrote: ↑09 May 2024, 04:53Feedback time for some of the added tweaks (disclaimer: I'm mainly focusing on input delay and feel).
I checked HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management but it wasn't there, so I can delete them. Perhaps I haven't made all the "updates" of this post, so it's missing? Can you check it's Registry Path? Thanks.
Re: kernel tweaks, updated May 10
day to day update
I'm done for the time being. Another thing I did to improve latency was unlock csrss and dwm because changing their priority didn't work correctly. Now I have 2x csrss and dwm assigned to a single core, running csrss at realtime and dwm at low. Also put 2x fontdrvhost on a single core at low priority and audiodg on a separate core without changing its priority. If someone doesn't know these can be changed in the details tab of task manager or Process Hacker, Explorer or Lasso. Unlocking csrss and dwm is done by installing wind64, opening cmd and putting in the command wind64 /d "process id". After unlocking them, I recommend deleting wind64 as it blocks games from opening and also adds input lag.
