GPU Scaling can't 75hz
Kruzh1337
Post by Kruzh1337 » 04 May 2024, 23:45
Hi, i notice when i turned on GPU SCALING in amd settings, the game felts TOO MUCH SMOOTHER and with 0 input lag, in comparison with display scaling (turned it off), BUT, i cant choose 75hz, i have 75hz only in 1024x768 not in native (1366x768) so thats the proble, i play cs like 15k hours in 75hz and playing in 60hz is killing me and i don't want to play with display scaling nevermore, is there a solution to play at 75hz with gpu scaling with no 75hz native?
Lev1n
Re: GPU Scaling can't 75hz
Post by Lev1n » 07 May 2024, 01:41
Get timings from cru and create custom res at your gpu software. I was able to do this when i was trying to force true display scaling but i was on nvidia.
Post by Slender » 07 May 2024, 09:14
Kruzh1337 wrote:
04 May 2024, 23:45
download cru and sre
delete all resolution exept 1366x768 75hz in cru
delete all resultion in sre and make you gpu scaling res.
now you have 2 resolution in total
1) 1366x768
2) your scaled resolution
if you dont have 1366x768 75hz you can try to make resolution in cru but best way to use gpu scaling is 1 native resolution in cru and 1 scaled resolution in sre
