Hi,
I have been reading up about monitors for the past couple of weeks to find out which one would suit my play style, and think a low input lag monitor would be best for me. But I am unsure about some questions;
-After reading Best Twitch-Type Gaming LCD? I think the best monitors are the BenQ XL2420Z and the Asus VG248QE for low input lag, does any monitor have an input lag advantage over the other?
-Does the new ROG SWIFT PG278Q have an input lag advantage over the BenQ XL2420Z and the Asus VG248QE?
-And would the 240Hz Non-interpolated zero-buffer display made last year have the best input lag compared to these?
Thank you for your help
-Loud
A few questions about monitors input lag.
Re: A few questions about monitors input lag.
Hi LoudCallum
If I remember correctly, the Asus one had a very small advantage on the tests I've read.
Yes.LoudCallum wrote:I think the best monitors are the BenQ XL2420Z and the Asus VG248QE for low input lag,
They have about the same amount of input lag.LoudCallum wrote: does any monitor have an input lag advantage over the other?
No.LoudCallum wrote:-Does the new ROG SWIFT PG278Q have an input lag advantage over the BenQ XL2420Z and the Asus VG248QE?
Yes.LoudCallum wrote: -And would the 240Hz Non-interpolated zero-buffer display made last year have the best input lag compared to these?
Monitor: Gigabyte M27Q X
Thanks, appreciate that
Also do you have a link of the tests? I thought they would be the same because of the shared panel but I suppose there could always be a software difference.
In fact, if anybody knows, if a monitor has less than 2 frames of input lag (16ms if i remember) does it matter what the actual input lag is since it will always be a frame after the gpu?
