Hello i would like to begin with this is my first time posting on this forum.
I am looking for help picking out a good PC and Console gaming monitor with the lowest possible input lag and fast response time i have been looking into a couple monitors but i cannot decide on which to buy.
So these are the monitors i have been looking at BenQ RL2755HM, BenQ RL2455HM, BenQ RL2460HT, and the Asus VG248QE. if anyone can help me pick a better monitor or can help me decide on which to get (i am not only locked on these monitors.)
Specs i want to help me pick a good monitor: 1080p, 24" or 27" must work with PC and Console gaming because i do both. Must have lowest possible input lag and fast response time, colors are important but i know TN panels wont have amazing color reproduction and i already know this i do not want a IPS panel because the response time is to low and input lag is horrible. and i do not really care about high refresh rate monitors like 144hz or 120hz because i have been gaming on a 60hz refresh rate monitor forever now and i am used to it so 60hz is good enough for me also when i play games with my console the extra refresh rates wont do anything anyways but that being said i do, do alot of PC gaming more than anything and i only have a GTX 670 2gb ftw edition and a i5-3570k not overclocked CPU with 8gb ram so i woulnd't be able to push 144 frames anyways untill i upgrade. (Height adjust is important also)
i am located in Canada and this is where i plan on buying a monitor from its a local PC store where i live http://www.memoryexp...s/Location/WpgW so if you can help me pick one from here that would be great!
Gaming platforms i plan to use this monitor for: PC/PS4/Xbox1 and Wii U
Gaming genres i play : Fighting games, FPS, RPG, MMO, Zombie games and survival and more
Main reason why i want a fast response time and lowest possible input lag monitor is for Fighting games because the monitor and tv i currently use has terrible input lag problems.
Fighting games i play DBZ Xenoverse, Super smash bros wii u and mortal kombat and others.
Thank you for taking the time to read my thread and thank you in advanced for any help and suggestions on which monitor i should buy its greatly appreciated
Looking for a good PC and Console Gaming Monitor
- lexlazootin
Re: Looking for a good PC and Console Gaming Monitor
Buy a Benq RL series. They do 60hz and have the lowest input lag of all monitors. I can't tell which one to get because the difference between these monitors are very small changes.
