Page 1 of 2
Nvidia Settings and Resolution question
Posted: 12 Sep 2015, 19:03
by spacencs
Hey guys, im new to this community. I really have no knowledge when it comes to input lag. So I have tow questions.
1. What are the best NVidia Settings for the least input Lag?
2.(Important one) So I play 4:3 Stretched CS
2.1 GPU or Display Scaling, do both options add Input Lag?
2.2 I have a custom Resolution 1440x1080, does that add more input lag than lets say 1024x768?
Thanks for every answer, hope I did everything allright, its my first post
Re: Nvidia Settings and Resolution question
Posted: 12 Sep 2015, 19:29
by Q83Ia7ta
Posted: 12 Sep 2015, 20:30
by spacencs
Its preference, still doesnt answer my question, still thanks for input
Posted: 12 Sep 2015, 22:09
by lexlazootin
No, all of those settings are pretty much identical.
+1 to Q83Ia7ta. Just use 1080p, playing 4:3 Stretched isn't going to make you good.
Posted: 13 Sep 2015, 09:27
by spacencs
Thanks for the answers, I just prefer it
Posted: 13 Sep 2015, 12:00
by Q83Ia7ta
spacencs wrote:Its preference, still doesnt answer my question, still thanks for input
2.1 yes but iirc GPU adds more
Posted: 13 Sep 2015, 17:10
by Falkentyne
spacencs wrote:Hey guys, im new to this community. I really have no knowledge when it comes to input lag. So I have tow questions.
Nvidia drivers have been known to add several frames (no more than 4) but at least 2 of input lag when GPU scaling is enabled. This has been a complaint about Nvidia drivers and I don't use an Nvidia card so I don't know in which drivers it was fixed, if at all. One frame at 120 fps (120hz) is 8.3ms so that can be a problem. Display scaling all depends on the monitor scaler (Benq's don't add any for 1:1 or full screen (1 frame at most) but the screen emulation sizes -do- add input lag that can be noticed).
Resolution differences below native are irrelevant. 1024x768, 1440x1080, 1280x960, all the same.
I can't tell a difference between GPU scaling on AMD cards or Display scaling. I don't think there's a problem in team red.
Posted: 14 Sep 2015, 07:05
by Q83Ia7ta
On BenQ XL2411Z there is only GPU scaling (no monitor scaling) available and i'm 95% sure there is no any additional input lag if native resolution is set.
Posted: 15 Sep 2015, 11:18
by stirner
Use NVIDIA Inspector and then just disable all post-processive graphic effects, set power management to maximum performance, use single-display performance mode, set pre-render to 1 frame.
Display Scaling if available (monitor has internal scaling capabilities) and "No Scaling" for both Display or GPU-sided scaling mode. Set your game to run at your monitor's native resolution if you really are as fussy about input lag (that is if your monitor does the same refresh at its native resolution of course). Use your monitor's "game mode" if it should offer something like that.
That's about what you can do.
Posted: 25 Oct 2015, 14:17
by urut
stirner wrote:Use NVIDIA Inspector and then just disable all post-processive graphic effects, set power management to maximum performance, use single-display performance mode, set pre-render to 1 frame.
What i should disable in nvidia inspector to minimize input lag?
