Overwatch + G-Sync input lag?
microsista
Post by microsista » 31 May 2016, 04:00
normally with g-sync you cap your framerate at 138fps on 144hz screens to reduce input lag, but in overwatch if you dont use in-game display-based (framerate+10, so 154fps) framerate cap, and exceed it, you have one-frame thread lag feature enabled which increases framerate, but adds a significant delay, what are optimal settings in this game with g-sync monitors? should i disable g-sync in this game?
lexlazootin
Re: Overwatch + G-Sync input lag?
Post by lexlazootin » 31 May 2016, 10:24
Maybe try using something like Nvidia inspector too add a driver fps cap too the game.
They REALLY overlooked having a custom fps limit.
Post by RealNC » 31 May 2016, 14:02
Try the RTSS frame rate limiter. (It comes with MSI Afterburner.)
lexlazootin
Post by lexlazootin » 31 May 2016, 20:41
When i was messing around with Fallout 4 and G-Sync i was getting screen tears with RTSS frame cap so i tried Inspector and it worked, but who knows, i might of done something wrong :)
pygmy
Post by pygmy » 03 Jun 2016, 11:28
You can limit FPS to whatever you want by editing the config.
https://www.youtube.com/watch?v=Dsdshm_4T5c
Karvapallo
Post by Karvapallo » 10 Aug 2016, 19:17
They finally patched the game, so it's possible to change custom FPS cap from the video settings:
Image So far I'm using 135, unless someone can measure settings that provide better input lag.
sharknice
Post by sharknice » 11 Aug 2016, 02:56
Karvapallo wrote:They finally patched the game, so it's possible to change custom FPS cap from the video settings:
I'm also using 135, it feels noticeably more responsive. I haven't run any actual measurements though.
lexlazootin
Post by lexlazootin » 11 Aug 2016, 22:57
I know it's not overwatch but when i was testing it with CS:GO 135 was low enough to not enable V-Sync but it depends game to game and how shitty their fame capping is. But remember that you can always disable V-Sync in your driver so if your frame rate ever gets high enough it will just tear instead of V-Syncing.
Start raising the cap and you will slowly start to see frame tears at the bottom of your screen.
I took these awhile ago and this is what they look like when i was no clipping sideways at 140fps in CS:GO and CS:S.
sharknice
Post by sharknice » 12 Aug 2016, 13:33
Nice! That's a good way to test the limit, because you can actually see the tears and get pictures whereas the input lag is difficult to observe and measure.
