2017 STROBE UTILITY [Version 1.x]
Re: NEW 2017 STROBE UTILITY -- ZOWIE XL2411, XL2420, XL2720
sure no pressure, just excited
A few months later now, any news?
The 480 Hz monitor stuff has bumped things a bit; my apologies!Bishi wrote:A few months later now, any news?
Hi
I have install the blur reduction (from then my counter strike global offensive does not start annymore i have to do cache clearing.. dont now of its about the blur software)
When i do all this steps https://www.blurbusters.com/benq/strobe-utility
i set refresh to 120hz Change Vertical Total to “1350” all that works.
But when i go ingame counter strike global offensive or on desktop now and i go look from the menu on my screen and go to information then he says current resolution 60 hz it have to be 120 hz ? or how does that come?
Amazing. Thanks for the updated Strobe Utility. Now i can finally use it on my 2720z again
@aresmaximus0408: The monitor suppose to show 1920x1080@60hz if your vt tweak is active.
@zuzpeqt Ok thnx then it works correct here.zuzpeqt wrote:Amazing. Thanks for the updated Strobe Utility. Now i can finally use it on my 2720z again
From the moment i have install blur buster counter strike global offensive dont start annymore cane somebody help ?
Most common cause:aresmaximus0408 wrote:From the moment i have install blur buster counter strike global offensive dont start annymore cane somebody help ?
VT1350 mis-tweak. If you see the monitor go blank, that's usually the custom timings fault (e.g. VT1350 failure). You have to make sure that the numbers entered in ToastyX CRU or NVIDIA Control Panel.
Less common, this may not be your problem, but this is included:
One possible situation is that there is a simultaneous situation of VT1350 + strobe phase beyond Strobe Utility range. In early XL2720Z firmwares, this caused the screen to go blank. This can be fixed by using either Service Menu to reset Strobe Phase, or using a 2nd monitor to reset strobe phase, before restarting the game. Then your VT1350 tweak will still work.
Alternatively, In a hurry, remove VT1350 tweaks
Simply remove your VT1350 tweak that you made to NVIDIA/AMD/ToastyX software. Everything should return to normal, regardless of the exact VT1350-related glitch above. You can still use Strobe Utility to improve your strobing without using the VT1350 tweak.
Ok thnx all, its works now csgo with the tweak and he shows 60HZ so its ok.
cane you use the tweak on lower resolution like 4:3 on 1280*920 ?
Hi. Any word on the 1.6 version for the xl2730?Chief Blur Buster wrote:The 480 Hz monitor stuff has bumped things a bit; my apologies!Bishi wrote:A few months later now, any news?
Hi, does the utility work on XL2411P (version with display port)?
