Check the other thread in my previous posts.
I wrote exactly how to apply a VT 1500 tweak and exactly what timings to use. You really need to spend more time searching and reading, because typing this is VERY time consuming.
But since I'm in a good mood I'll tell you exactly what to do. but please in the future, read these forums more carefully as all of this stuff has been explained step by step to the finest detail.
1) download custom resolution utility and the driver restarter here:
http://www.monitortests.com/forum/Threa ... tility-CRU
From the same page, download either the AMD or Nvidia pixel clock patcher
http://www.monitortests.com/forum/Threa ... ck-Patcher
2) run CRU and make a VT tweak for 100 hz if you want (keep in mind that you can NOT use virtual super resolution (AMD) or Nvidia's DSR with custom resolutions, so if you do use these, you may want to make separate cru profiles (you can 'export' your current CRU settings into a bin file and save it, and "import" it later). e.g. if you try AMD's VSR with a 100hz VT tweak active, when you go to 2560x1440, it will only be at 60hz instead of 100hz.
Anyway:
for 100hz and a VT 1500 tweak, all you have to do is click "Add" (manual-detailed resolution) and 1920x1080,
Front porch and sync width should be default of 88/4 (front porch, for pixels and lines) and 44/5 for sync width (pixels and lines).
Back porch and blanking will fill in automatically.
Horizontal total should be 2200 (default), Vertical total will say 1125. Change this to 1500.
This should give you EXACTLY 330.00 MHz pixel clock (this should work without the pixel clock pater). If you used VT 1502, which is the MAX possible value before you go "out of range", that's 300.44 MHz and requires the patcher since you're above 330.00.
For 120hz, REQUIRES THE PIXEL CLOCK PATCHER, and you should probably use lower timings (similar to the ones "strobelight" installs), because using the same timings, would put you at 396 MHz pixel clock, and you might have swimming pixels depending on your DVI cable and video card. I do NOT know about displayport or its limits! YMMV on displayport.
120hz:
1920x1080
48/3 front porch (lower than default)
32/5 sync width (lower than default)
2080 horizontal total (down from 2200)
1500 VT
Should put you at 374 mhz. This will REQUIRE the patcher.
If you absolutely do NOT want to use the pixel clock patcher, then you would have to use 2020 or 2040 horizontal total and you would be limited to 1350 Vertical total (whatever keeps you under 330 MHz), but when using VT tweaks, the OSD's scaling options (under display mode) get messed up anyway, so you might as well just use a VT 1500 to improve the quality of the blur reduction (by having the crosstalk settling errors at the top and bottom of the screen as far away as possible).
you can save and export your settings to a file.
After you make your changes and press OK to exit CRU, BEFORE restarting the driver, make sure you run the pixel clock patcher *FIRST*. The values must be patched BEFORE you restart the driver. Only then will your VT Tweak take effect.
Also make sure strobe phase is set to 000. High strobe phase values when using VT tweaks may blank the backlight if blur reduction is enabled.
Enable single strobe if you know FOR A FACT that you will never ever have the screen set to 50hz by an errant game (Hi, Crysis, I'm looking you) or by accident--there's a bug with single strobe and 50hz where the monitor won't enter strobe mode at all. Double strobe works fine. if you have single strobe DISABLED, 100, 120 and 144 hz will ALWAYS single strobe anyway, HOWEVER, toggling off and on blur reduction will cause 'default' strobe values to be used, until strobe phase, duty or brightness is changed. (this annoying problem (bug) can be avoided by enabling single strobe, which ALWAYS applies custom values instantly, or by activating a profile on the S-switch or "picture mode' (activing a profile resets the brightness, and as I said, changing brightness avoid this "bug"
VT 1500 tweak should never give you a problem at 100 and 120hz. Vt 1350 works also, (but you will have more crosstalk between the top and bottom of the screen).
That's all.
