Hello Everyone
My monitor is still reconize as standart pnp monitor trying another cables, settings almost everything what should work but it dsnt and my resolutions in osd panel is display wrong, in cs go when i put a 1280/720 on osd is shown as 1280/1024 and trying to stretch it...
I feels like i need manual EDID override so all what i asked for is benx xl2411z.inf file. If someone of You guys have this monitor and everything is work can You create and send me that file?
if u dont know how to create a monitor inf file -> http://3dvision-blog.com/forum/viewtopi ... =14&t=2025
BENQ XL2411Z Drivers problems
Re: BENQ XL2411Z Drivers problems
its on the driver DVD. You need to update driver from device manager or display in control panel then browse and "have disk" I think, and install that way. And 1280x720 / 960 are identified as 1280x1024 whether you like it or not anyway. You can use the video card aspect / scaling settings to fix that (forgot if the monitor osd has to also be set to 1:1 or not, though). Or avoid that bug and use 1152x864 or a custom res 1440x1080---even better. 4:3 with no black bars above or below and 1:1 mapping.
The problem is i dont have disk with drivers since its in my family house (150km away from me) too much waste fuel to go for it so im looking for other method.
Thanks for Reply anyways
Should be on the benq website. You don't need the driver disk anyway. Just the windows utility may not work without it. The monitor is Plug and play.
The 1280x960/720 bug happens even WITH drivers installed. It happens on my XL2720Z.
