Hey mate,Falkentyne wrote:I read what you said.
So that blurry area does NOT change as you change the strobe phase (Area in the OSD) from 0 to 60?
Interesting.
How about this.
What happens if you play a FPS fast paced game at 120hz?
Is your game also blurry at the same area?
What about just moving a notepad window full of text, dragging it around on the desktop?
That's easy to test. Just drag a window around on the desktop. The only distortion/ghosting you should see should coincide with the strobe phase change.
Sorry about the delayed response.
Okay so I tested the notepad test (page full of tests). At strobe 000 the ghosting is very apparent down the bottom (as it should be) and when I move the strobe feature, the ghosting moves with it.
The problem *only* appears in the UFO test website. Have no visible problems @ 1080p / 120 hz / blur reduction ingame.
A friend of mine also has the same monitor as me. We went through all the same settings together and I can confirm that his OSD did *not* change to 60hz after making the changes. Considering the noticeable colour boost benefit after applying the VT 1502, is it fair to say the tweak is working and I am just getting browser lag/stutter? I tried it in the new Firefox but the site cakes it a bit.
As I said in game (CS for instance) at 1080 / 120hz / blue reduction, it looks good. My FPS suck balls and isn't sustainable, but it looks good.
I fly back home in around 16 hours, so can test anything you like there.
