well brought this monitor after rave reviews but it literally blinds me.
i have tried all sorts of colour set ups and few icm profiles.
does those that are happy with theirs can you pls post your settings cause i just cant get past how bright it is.
any help is appreciated.
benq zxl24llz colour set up brightness v3
Re: benq zxl24llz colour set up brightness v3
Hey Dgee,
If it's just brightness, try it with blur "reduction on" using Standard settings and adjust accordingly.
If this is still too bright you could essentially install the blur buster utility then turn single strobe on and lower persistence even more.
http://www.blurbusters.com/benq/strobe-utility/
mode: standard
brightness: 100
contrast: 55
LBL: no
blur reduction: on
color temperature: user mode: (R: 96, G: 99, B: 95)
ama: high
instant mode: yes
sharpness: 6
gamma: 4
mode: standard
brightness: 100
contrast: 55
LBL: no
blur reduction: on
ama: high
instant mode: yes
sharpness: 6
gamma: 4
what icm profile you using ?
i tried your settings not bad but colour bit odd but then again depends on what icm profile you using.
as for setting up the blur busters utility any guides ? thanks!
currently using the win 7 default icm (
You'll have to mess with icc profiles from review sites and see which you like best.
Same for blur buster, I primarily play consoles so have persistence to 1.5-2ms and crosstalk to 0.
Colors will always be somewhat lacking due to tn panel. If your card is nvidia, you could play around with vibrance.
