Just bought XL2411z, banding issue, ghosting ++
Re: Just bought XL2411z, ghosting issue++ Help!
So you want me to read something you don't remember what is or where is, instead of just telling me. Did i get this right?
Yes. Just look at the threads. I mean I cant do EVERYTHING for you, can I?
I spent the entire morning helping you and not even a single thank you....just more being taken advantage of.
You're on your own.
You're on your own.
I've thanked you earlier and my apologies for thanking you after every post, did really not think that was necessary.
Telling me to just read all the others threads does nothing when I don't know what I'm looking for, i thought that was obvious.
And I do need everything explained and almost done _for_ me, cus I don't know the first thing about what I'm doing and it's rough for me to grasp. If I didn't need extensive help I wouldn't be here in the first place.
Also now that I know that effect is called banding i realize the monitor has abit of it to reach to 144hz and 1ms.
Sacrificing quality for response time, yes?
Still haven't fixed the issue, still need help.
Re: Just bought XL2411z, banding issue, ghosting ++
You probably notice gradient banding because the contrast is scarified the higher refresh rate you use and banding is easier to see the lower the contrast is. Go into your menu and make sure Gamma 5 is set. Other than that, the only other option is dropping your refresh or trying a professional calibration tool.
