Strobe Utility Resets Settings Each Time
Mortykai
Post by Mortykai » 23 Dec 2015, 21:15
Hello, I received my first good gaming monitor today and I've been messing with it all day. One thing I've found is that the Strobe Utility reverts my settings to default every time I open the program. Any help is appreciated!
Falkentyne
Re: Strobe Utility Resets Settings Each Time
Post by Falkentyne » 23 Dec 2015, 22:59
Does it say 'supported monitor found'?
What happens if you open the Service Menu and look at the strobe settings? What do they say there?
If the settings keep resetting somehow, it would say "strobe phase 100, Strobe duty 020 and single strobe=OFF
(Service menu codes here: http://forums.blurbusters.com/viewtopic.php?f=13&t=2590 )
Do you have display pilot installed?
Mortykai
Post by Mortykai » 24 Dec 2015, 03:42
It says that a supported monitor is found. Also, when I say it resets the settings, I mean that the actual slider bars in the Strobe Utility keep going back to their original positions when I open/close the program. I also have the display pilot installed. Thanks for the help!
