Hei.
I just installed windows 10 and get fault message about the .NET Framework software when trying to install strobe utility.
It says it requires 3.5, but I have already a newer version installed.
Any ideas what to do?
Can't install the strobe utility - Win 10
Re: Can't install the strobe utility - Win 10
You don't need the strobe utility. it's a front end for the Service Menu, which also stops you from accidentally setting the strobe phase too high when using a VT Tweak, which will turn off the backlight. You can unlock the service menu and make the settings yourself. You also don't need to alt tab out of a game.
Please read this thread to unlock the service menu.
http://forums.blurbusters.com/viewtopic.php?f=13&t=2590
How you know he has BenQ?
Just assumed since he wants to use the utility.
Sorry I didn't notice forum where he posted topic(thread). Thought he may talk about strobelight by ToastyX or strobe utility.Falkentyne wrote:Just assumed since he wants to use the utility.
I have the Benq XL2720Z monitor and the Strobe Utility for Benq will not launch with Windows 10. Is this the same issue I am having and that I dont need the utility???
