helo,
im finally get the setting in my benq xl 2411z with blur reduction ON.
for info im playing cs:go atm.
im using strobe phase 43 and strobe duty 007 as if seen in other topic.
everytime im login my pc do i need to adjust the strobe again on my benq system?
because when im login in the blur buster strobe utility the persistence is going on above 0.5ms and crosstalk is almoust full on the right,
but when im set the persistence to 0.5ms and crosstalk to the left the monitor brightnes become darker again.
thank you for the information
Do i need to adjust the strobe utility everytime login PC?
Re: Do i need to adjust the strobe utility everytime login P
Check the service menu and see what the values are shown there.
You can look in the service menu as long as there is an actual display signal to the monitor, including on the computer BIOS screen, or windows loading screen or startup screen. You also want to make sure that Internet Café is not set to ON. Setting this to ON will cause the monitor to factory reset itself every time it's powered off or unplugged.
