XL2411z Weird Colors
Posted: 24 Apr 2016, 19:10
by Genesis89
Version 4 firmware. I downloaded an icc profile and it really helped with colors. For some reason there are little blurry around people in images and if it's related or not my windows 10 log in screen has weird color splotches in it. I took a screen shot and viewed it on my phone and strangely it looked completely normal! I don't know y
If the strobe utility is even working but I tried changing the bar back and forth I don't notice any changes. Help please.
Re: XL2411z Weird Colors
Posted: 24 Apr 2016, 22:44
by lexlazootin
Really vague...
Maybe it's your sharpness setting on your monitor?
Posted: 25 Apr 2016, 08:55
by Genesis89
Well I would show you a screen shot but it would look normal on your end.
Posted: 25 Apr 2016, 11:11
by IceCube
disable FXAA in graphics card drivers... fxaa makes everything look blurry
Posted: 25 Apr 2016, 19:27
by Genesis89
Okay I turned dynamic colors or something up in the graphics card settings on it. I'll try your suggestions and get back with you guys!
Posted: 25 Apr 2016, 22:52
by Genesis89
Well I see the sharpness all the way down made things blurry but up too high it amplified my problem. I'm not sure if this is related or not but I pulled some images from google. My log in screen on windows 10 looks like the first image where as on my buddies screen it looks like the 2nd....
I'm not sure if this is related to my first problem.
Secondly I couldn't find the FXAA setting in Nvidia control panel.
Does the strobe utility help fix the problem? if it does I can't seem to notice it on version 4 firmware. If it is working when I slide the bars back and forth I notice no difference.
Posted: 26 Apr 2016, 03:32
by lexlazootin
Can you take a photo and upload it too show the problem you are having? I still believe it might be the 'Sharpness' setting, does setting it too 5 out of 10 fix the issue?
I recommend leaving all of the colour settings in your control panel to default, changing them can cause more problems.
Don't worry about FXAA, if it's not in a video game then it's probably not the problem.
Is it the colour that looks different?
