xl2411z how to enable gamer settings?
ta0ako
Post by ta0ako » 17 Jun 2016, 01:39
where can i enable the settings after i save the settings? i can't find where to switch for example gamer 1 i want to switch it to gamer 2
monitor_butt
Re: xl2411z how to enable gamer settings?
Post by monitor_butt » 17 Jun 2016, 06:52
Picture advanced>picture mode> the last 3 are Gamer profiles you saved to.
It's more convenient if you change one of the shortcut keys to picture mode select.
urut
Post by urut » 17 Jun 2016, 12:45
How to do this shortcuts ? :D
Falkentyne
Post by Falkentyne » 18 Jun 2016, 01:03
You can't. All you can do is set a customized key (1-3) to "Picture mode". You can't set gamer 1-3 to a customized key. You have to go to picture mode and move the slider.
That's why the XL2420Z and XL2720Z are so useful. You just use the S-switch 1-3 settings (which are the gamer 1-3 profiles).
