XL2411Z Help! Overwatch Flickering in Fullscreen
Graced
Post by Graced » 24 Jul 2016, 18:04
This has really got me confused, when I first set up the monitor using blur reduction and the the 1350 trick this wasn't a problem, but I was having on and off FPS issues where the frame rate would be at 60-90 fps but it would feel choppy (just had this today). I reset the monitor and redid the settings, but when I opened Overwatch the game is now flickering only with blur reduction on, yet it doesn't flicker in a boarderless window.
TLDR: Game is flickering with blur reduction 1350 trick in fullscreen but not in a boarderless window, but is totally fine in fullscreen with motion blur off.
Falkentyne
Re: XL2411Z Help! Overwatch Flickering in Fullscreen
Post by Falkentyne » 24 Jul 2016, 19:06
Can you please post your EXACT timings?
All values.
Refresh rate, VT used, HT/VT, pixel clock, etc.
And don't ever use VT 1350 at 100hz. This only accepts VT 1354. VT 1500 is better for 100 and 120hz anyway.
Graced
Post by Graced » 26 Jul 2016, 03:46
Thanks for the reply, I'll save the information if a this problem reemerges. I managed to fix this problem by using ToastyX utility instead of Nvidia control panel, I heard Nvidia control panel can cause some problems.
