XL2411Z - Revert firmware V4 to V3
Posted: 15 Feb 2017, 06:49
by tonimakinen
Hi guys
Hi have updated my firmware to V4 but on BF4 the image is not fluid, so I tried to put the V3 version, but despite everything running okay and appear at the end "PASS" always continues in the V3 version.
Someone can help me?
Re: XL2411Z - Revert firmware V4 to V3
Posted: 15 Feb 2017, 13:54
by Falkentyne
Firmware should not affect BF4.
The XL2411Z has the exact same scaler as the XL2420Z and XL2720Z. So the scaler interacts with the video card in the same way.
Whenever you flash the firmware, the strobe phase changes to 100 after a flash. So you may want to lower that unless you are not using vertical total tweaks and want the lowest input lag possible.
What do you mean "PASS" always continues in the V3 version?
Posted: 15 Feb 2017, 20:11
by tonimakinen
When i use the program MSTAR ISP SOFTWARE in the final of the update must appear "PASS"
http://www.blurbusters.com/wp-content/u ... -step8.png, but the monitor still have the V4.
Posted: 15 Feb 2017, 20:31
by tonimakinen
