BenQ XL2720Z only showing 60fps in AlienInvasion Test?
Re: BenQ XL2720Z only showing 60fps in AlienInvasion Test?
This usually is the browser itself incorrectly detecting the refresh rate.
See http://www.testufo.com/browser.html for system requirements.
Can you verify that your Windows is not configured into Classic mode?
Hey Chief! Thanks for stopping by and giving me some advice.Chief Blur Buster wrote:This usually is the browser itself incorrectly detecting the refresh rate.
I was using Windows Classic mode but enabled an Aeros Window 7 theme and restarted.
I then installed the latest Firefox and Opera browsers and went to www.testufo.com
It still only shows 60fps as with the original chrome browser?
I checked my Nvidia control panel which shows 120fps setting is on.
I checked my Windows control panel display which also shows it should be running at 120fps.
Now I am confused as to what I am running? All 3 browsers show 60fps but my computer settings are 120fps.
Any further advice is appreciated. Thanks again.
http://forums.blurbusters.com/viewtopic.php?f=13&t=452
Thanks.
Do you think it was because I used the strobe utility FIRST instead of doing the VT 1350?1920x1080p 120Hz, optimized for clearest motion, but very dim
Sharper & Clearer Than LightBoost=10%, but dimmer
1. First, do the "Vertical Total 1350" Tweak.
2. In Strobe Utility, enable "Override"
3. Set "Persistence" to 0.5ms
4. Set "Crosstalk" to first tick (3 clicks up)
Thanks.
