hello i try to use 182hz with VT Tweak this is the setting my monitor accept 1584 is out of range
this one is so snappy amazing i wonder if its can cause any issues like damage the panel ? i cant stop playing
VT Tweak xl2546
VT Tweak xl2546
- DukeDice929
Re: VT Tweak xl2546
Wanna best crosstalk possible on various refresh rates?
Check out my settings below and tune "Area" via Strobe Utility (mine is zero).
*Although I've already sold it, still might be useful for someone.
https://ibb.co/80cgqBM
https://ibb.co/DbQmcSK
https://ibb.co/BKNw3sT
https://ibb.co/TtNHfZM
https://ibb.co/4ThZfnN
My bad English :0
Re: VT Tweak xl2546
DukeDice929 wrote: ↑26 Oct 2020, 09:15Wanna best crosstalk possible on various refresh rates? Try my settings below and tune "Area" via Strobe Utility (mine is zero). Although I've already sold it, still might be useful for someone.
thank u so muchh i just wondering if the 1578 vt is safe
- DukeDice929
Re: VT Tweak xl2546
IIRC you can't harm a monitor with altered VTs. Worst case it will go "out of range".
My bad English :0
Re: VT Tweak xl2546
oh ok thanks is 1578 bad compare to 1500? since its clean 182.000DukeDice929 wrote: ↑26 Oct 2020, 11:40IIRC you can't harm a monitor with altered VTs. Worst case it will go "out of range".
Re: VT Tweak xl2546
pox02 wrote: ↑26 Oct 2020, 11:44oh ok thanks is 1578 bad compare to 1500? since its clean 182.000DukeDice929 wrote: ↑26 Oct 2020, 11:40IIRC you can't harm a monitor with altered VTs. Worst case it will go "out of range".
i try 1650 VT and its works for 180hz to but reduced cru monitor
https://prnt.sc/v7vo98
Feels a lot better then 1500 VT thank u so much for area 0 its insane !!!! topic can be closed
- DukeDice929
Re: VT Tweak xl2546
Never used 1578 VT so can't say anything about it.
I'm glad it helped. Just in case, I saw your post in XL2546K thread and to clarify the setting I gave you earlier are for XL2546 (without "K"). Next time use proper monitor model name when creating forum threads to avoid misleading.
My bad English :0
Re: VT Tweak xl2546
yeah sure sorry its xl2546 the xl2546k come soon i want to thank u so much u bring me to my old days with crt that snappiness on 180hz its insane i cant stop playing mann !! thank u so muchhhDukeDice929 wrote: ↑27 Oct 2020, 13:00Never used 1578 VT so can't say anything about it.I'm glad it helped. Just in case, I saw your post in XL2546K thread and to clarify the setting I gave you earlier are for XL2546 (without "K"). Next time use proper monitor model name when creating forum threads to avoid misleading.
Re: VT Tweak xl2546
What you mean but with reduced cru monitor?pox02 wrote: ↑27 Oct 2020, 07:32i try 1650 VT and its works for 180hz to but reduced cru monitorpox02 wrote: ↑26 Oct 2020, 11:44oh ok thanks is 1578 bad compare to 1500? since its clean 182.000DukeDice929 wrote: ↑26 Oct 2020, 11:40IIRC you can't harm a monitor with altered VTs. Worst case it will go "out of range".
I cant get 1650 with my xl2546 at 180hz
or did you mean nvcp?
Can anyone tell me how can I archive VT 1650?
Re: VT Tweak xl2546
ok I made it,
I throw my dp cable into the bin and bought a hdmi 2.1 cable.
