Firmware upgrade using Linux tool, requires no hardware
CubanLegend
Re: Firmware upgrade using Linux tool, requires no hardware
Post by CubanLegend » 11 Dec 2020, 19:24
Sparrow wrote:
14 Mar 2020, 05:31
Today I tried again with firmware 007 and after there was an error message for the first time I started the flash again straight away and lo and behold, it worked and I'm now on FW 007. You don't have to understand why it is 10x not working and then suddenly it works. I really didn't do anything different at the time ...
well.. after trying this on V7, i was able to unbrick my XL2720Z.. !! :D Thank you for posting this! I was on the verge of buying a 2nd one to replace this one.. I can confirm from being on V2 and now on V7 that the AMA Low tweak does work! It's glorious
Falkentyne
Post by Falkentyne » 11 Dec 2020, 21:11
Glad it worked. I can't help with Linux anymore because I haven't used that method in years. I just use my Mstar ISP device.
acecommander144
Post by acecommander144 » 04 Jan 2021, 09:57
Hello everyone. I have a Benq Xl2720z on firmware v3 and would like to upgrade it to v8. I have a big problem tho; i am a complete noob with linux and i have not understood the guide that was published to do the firmware update. Could someone help me by writing the simplified steps i need to take in order to firmware update my monitor? Thanks alot in advance for your answers!
Margusx
Post by Margusx » 07 Jan 2021, 02:14
For newer monitor linux is outdated best what works is aliexpress MSTAR device in linux you can brick and unbrick but not all monitors work in there. What did work was 2411z to me but not 2536 it detected but gived lot errors so i considered dangerous to continue.
MSTAR ISP device on ali not expencive too but that works no issues.
raytracy86
Post by raytracy86 » 09 Feb 2021, 06:15
Thanks for that V7 trick. It actually helped :)
zn1p
Post by zn1p » 18 Apr 2021, 11:53
How do I know if there is a new firmware version for my monitor and where can I download it? I have XL2430 with a firmware v010-20161201
Square Ragnarok
Post by Square Ragnarok » 29 May 2021, 17:31
*Edit: Now obsolete*
havena
Post by havena » 28 Apr 2022, 13:08
hi on my V2 XL2411Z, i dont find "MX25L1605A/MX25L1606E" but "MX25L1605A/MX25L1606E/MX25L1608E"
and flash fail on it with V4 dump... any idea?
thx
