G-SYNC and RTSS
All Unidentified Forum Objects go in this area! Any fun alien talk goes in this U.F.O. Abduction Lounge, even topics other than monitors or computers. Introduce yourself!
Locked
Anonymous893125
G-SYNC and RTSS
Post by Anonymous893125 » 17 Oct 2022, 14:19
first question is about hdr if a monitor has the option to enable hdr would that have any ill effect at all or is there anything i should know about hdr at all ?
second question is about the full screen optomization option in windows ive seen a couple people talk about it and im just a bit confused if i should leave it as it is or not
and lastly is about the game mode option should i have this on or off ?
thanks guys will appreciate any replies.
Re: a couple questions
Post by jorimt » 17 Oct 2022, 15:38
Anonymous893125 wrote:
17 Oct 2022, 14:19
Depends on the monitor model implementation and game. HDR is more related to picture than performance in games.
17 Oct 2022, 14:19
Fullscreen optimizations is the default in Windows 10 and later, and applies a hybrid fullscreen/borderless mode that acts like exclusive fullscreen when the game window is focused, but allows adaptive DWM when the game window is unfocused for quicker alt+tabs and support for external OS-level overlays like the Windows game bar, volume bar, etc.
17 Oct 2022, 14:19
Game Mode sets a higher priority on the currently open game process and prevents Windows from downloading or installing OS updates while the game is running.
I leave it enabled (on Win 11), but up to you.
Displays: ASUS PG27AQN, LG 48C4 VR: Beyond, Quest 3, Reverb G2, Index OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboards: Wooting 60HE, Logitech G915 TKL Mice: Razer Viper Mini SE, Razer Viper 8kHz Sound: Creative Sound Blaster Katana V2 (speakers/amp/DAC), AFUL Performer 8 (IEMs)
Anonymous893125
Post by Anonymous893125 » 17 Oct 2022, 16:13
would i be best just leaving hdr mode to off then just turning it to on when i want to play a hdr title ? (res evil village for example)
for the full screen optimizations should i leave it as is ?
and yeah i think ill keep game mode on too
Anonymous893125
Post by Anonymous893125 » 17 Oct 2022, 16:24
and is full screen optimization's turned on on every app by default ?
Post by jorimt » 17 Oct 2022, 16:25
17 Oct 2022, 16:13
What is your monitor model?
17 Oct 2022, 16:13
For 99% of games, if you're running them in exclusive fullscreen, there's no reason not to leave it enabled (it doesn't affect games run in borderless or windowed mode).
The only games I personally disable fullscreen optimizations for is the DX11 Souls series, since they lock the physical refresh rate to 60Hz if you don't.
17 Oct 2022, 16:24
As far as I'm aware, yes, it's the system default for every game on the latest versions of Windows 10 and 11.
Anonymous893125
Post by Anonymous893125 » 17 Oct 2022, 16:39
i dont actually have a g sync monitor yet im just doing my homework before owning one soon just want to get a full understanding
Anonymous893125
Post by Anonymous893125 » 17 Oct 2022, 16:40
the one i want though is the ASUS TUF Gaming VG27BQ
Anonymous893125
Post by Anonymous893125 » 17 Oct 2022, 16:50
what can i do to check if i need to disable fullscreen optimizations in game ? i know you said in dx 11 dark souls games it locks to 60 would it be that same behaviour for all games or different ?
Post by jorimt » 17 Oct 2022, 17:21
17 Oct 2022, 16:40
Don't bother enabling HDR mode on that model then. Peak brightness on that panel is 350 nits, and you need at least 600 nits for a decent HDR experience. It's just a gimmick at that nit level, especially on TN-type panels, which don't have near enough of a contrast ratio to be effective for HDR.
Basically, that model will look better in SDR mode.
17 Oct 2022, 16:50
Again, it's a Souls-specific quirk. I've played hundreds of games with fullscreen optimizations (which has nothing directly to do with G-SYNC, by the way), and that's the only engine I've experienced that issue (or any like it) in.
Anonymous893125
Post by Anonymous893125 » 17 Oct 2022, 17:33
ok its good to know that i have this fourum to come to if anything happens i dont undestand,
in RTSS if i got one fps limit in global set to lets say 80, then in RTSS for a program do the two overlap ? or can i leave them both on the same time or is this the same case as nvcp the global version applies to everything, unless you override it per game profile ?,
or do i need to make sure i set global to 0 if im ever using one of the games i got a custom limit for within RTSS ? hope this makes sense
Locked
