hdd ssd ahci bios settings
Posted: 12 May 2023, 10:44
i have no option in bios where i can switch from hdd to sdd and only ahci option exists there...
but when i was looking in biossettings with scewin i find many of this:
Setup Question = SATA Device Type
Token =76F // Do NOT change this line
Offset =BB8
Width =01
BIOS Default =[00]Hard Disk Drive
Options =*[00]Hard Disk Drive // Move "*" to the desired Option
[01]Solid State Drive
the * is set everywhere to HDD by default...
but im running windows 10 on M.2 SSD...
is that normal ? should it be not set to Solide State Drive in bios automatic and detect when install and run an SDD in pc ?
same happens on another motherboard too...i install and run sdd but scewin shows bios default HDD and the * is set to Hard Disk Drive.
Offset =BB8
Width =01
