Hello.
https://www.hisense-usa.com/100l8d
At 50/60 Hz, Laser TV with flicker simulates to CRT, ok?
New Laser TV! With flicker?
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 non-OC new! <3
HDD: SATA 1TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: CRT 19" Samtron 96BDF
HDD: SATA 1TB
Re: New Laser TV! With flicker?
Depends on the laser implementation.
Most laser TVs are DLP-based TVs, so are effectively sample-and-hold projection displays that are ultra-short-throw. Basically DLP chips illuminted by a laser light source (instead of HID or LED) permitting an ultra-short-throw with minimal lenses. Those won't be low persistence.
Only a few laser projectors are direct scanning based. THOSE are amazingly low persistence, and it was posted here in this 2014 thread. I'm keeping an eye out for higher-definition implementations, as direct-beam laser projectors are practically zero-persistence.
