Page 1 of 2
OLED 0,1ms response time and 120Hz?
Posted: 08 Jan 2016, 13:44
by Q83Ia7ta
Re: OLED 0,1ms response time and 120Hz?
Posted: 08 Jan 2016, 19:16
by jlafarga
oh my fucking god, its finally happening!!!
Posted: 09 Jan 2016, 02:46
by Glide
Don't forget that response time is meaningless unless they have black frame insertion options.
0.1ms response times, 17ms of motion blur at 60 FPS due to sample & hold.
Posted: 09 Jan 2016, 06:42
by RealNC
Glide wrote:Don't forget that response time is meaningless unless they have black frame insertion options.
Even without, I'll take it. If it eliminates ghosting and overdrive artifacts, it's gonna be an improvement even without any strobing or black frame insertion.
Posted: 09 Jan 2016, 12:09
by masterotaku
It would be perfect for 3D, with real blacks that wouldn't distract me, and zero crosstalk. But it seems it won't even have Freesync or G-Sync.
Posted: 09 Jan 2016, 18:54
by spacediver
wow.
Posted: 09 Jan 2016, 21:54
by sharknice
The sooner this is released the sooner we will get OLED displays with low persistence options and eventually low persistence gsync/freesync.
Posted: 09 Jan 2016, 22:19
by Falkentyne
masterotaku wrote:It would be perfect for 3D, with real blacks that wouldn't distract me, and zero crosstalk. But it seems it won't even have Freesync or G-Sync.
If Masterotaku could find a monitor with OLED, full 3d vision support, no burn in, motion blur reduction by strobing the LED's, Gsync and freesync in the same panel, 10 bit color, and variable refresh rate strobe support, and 27-32" or higher, I think he will die and go to heaven and be happy forever after.
Posted: 11 Jan 2016, 12:57
by nuninho1980
If this OLED monitor has
0.2 ms or shorter persistence time (IMPORTANT: NOT equal to response time
) then I'll buy it.
Posted: 11 Jan 2016, 14:15
by Glide
Well we know that it won't. It will probably be a completely flicker-free display.
But 0.2ms seems like a rather steep goal considering that CRTs are in the region of 1-2ms.
