Monitor: Benq EX2510
I was using this monitor with a GTX 1060 in GYSC Compatible mode. I could confirm that Freesync/GSYNC was working because in the monitor menu I could see the Hz value fluctuating with my FPS.
Now I have an XR 6700 XT and I believe freesync is not working because in the monitor menu the Hz value always stays at 144Hz even if my FPS is lower.
Can anyone with the same monitor confirm if they have the same behavior? Is this normal?
Monitor OSD always shows 144Hz
Re: Monitor OSD always shows 144Hz
My problem is flickering! I can’t seem to get it to stop
I have the EX2510s version.
I vaguely remember having variable hz in the monitor menu, perhaps I was on my nvidia 2080s back then.
Now I'm on AMD 6800 and the refresh rate always shows as 165.
I also don't know if this is normal or if freesync isn't working
