Freesync and temporal image retention?
Crazyness
Post by Crazyness » 22 Dec 2022, 07:00
On non native resolutions,acer 390hz is a beast.
it can deliver anything you want..
best way to look at it is like this..
depending on your system you can adjust resolution and hz..
example1
you are cpu bottlenecked, go for higher resolution
3840x2160 140hz 120hz 100hz(choose hz matching your max fps)
3840x1440 230hz 220 210 etc (max hz=max fps)
3840x1200 240hz 230 220 etc (max hz=max fps)
2560x2160 185hz 180hz 175hz(max hz=max fps)
2560x1440 300hz 280hz 260hz(max hz=max fps
example2
gpu bottlenecked,go for lower resolutions
actually native 1080p is still cpu bound
so stay native or go bellow
960x540 400hz
480x270 400hz
or first person shooters popular like
1024x768,800x600 400hz etc..
So as you can c,pretty much beast..
so here comes the actual question..
every single resolution is ok especialy lower 1s
on higher 1s there is an issue,bcs every single resolution
that i just described works flawlessly without Freesync Premium
as soon as i turn freesync premium on,bugginess acure
like image retention is stronk in this 1
sometimes it will just freeze like you can not even enter the menu etc..
so is it bcs max pixel clock?
or is it hard coded parametars and works only bettwen those?
or wat it is it?
4k res will work flawlessly other not so much..
Re: Freesync and temporal image retention?
Post by Chief Blur Buster » 13 Jan 2023, 00:58
It's quite possible that there's a inversion algorithm bug with the FreeSync mode on this model.
Most QA test only using GPU scaling, rather than monitor scaling, and that monitor scaling might have a bugged inversion algorithm.
Does your model have a firmware upgrade?
Image retentation on LCD = usually inversion algorithm related
viewtopic.php?f=7&t=7539
Crazyness
Post by Crazyness » 11 Feb 2023, 13:30
Chief Blur Buster wrote:
13 Jan 2023, 00:58
All image retention is fixable in 30sec with watching any 4k video full screen per your advice Chief!
sorry for late response..we are similar age so you know..sometimes we forget things :D
there is no software update curently..
and you can prrety much avoid retention
if you are in 6-8-10 bit timings
as soon as you go beyond with totals..
and drop into automatic conversion into reduce yccbr retention is there..
so 20-30hz bellow max on desired res,
and you are ok..
example 4k 144 freesync retention is there
120hz and its all good
1440p 300hz its there,270-280hz and you are good 2 go.
