Blur Busters Forums
Freesync drivers are finally out!
Talk about AMD's FreeSync and VESA AdaptiveSync, which are variable refresh rate technologies. They also eliminate stutters, and eliminate tearing.
Postby Edmond » 20 Mar 2015, 03:44
http://www.techpowerup.com/210846/amd-a ... l#comments
Someone got to test if freesync flickers are severe fps drops like gsync does!
Not to mention to find if it has any surprises hidden!
Edmond
Re: Freesync drivers are finally out!
Postby DancingDirty7 » 21 Mar 2015, 09:11
Anyone wants to try it out, FreeSync is in the beta drivers 15.3 and only works with single cards(AMD)!
DancingDirty7
Postby Edmond » 22 Mar 2015, 06:13
http://www.pcper.com/reviews/Displays/A ... -FreeSync-
Go read the bit about ghosting in this review.
As far as i can understand - freesync has noticeably more ghosting than gsync. Something to do with voltage tuning. I wonder if this is just a defect of LCD and would go away with OLED?
Also, in that review there is some explanation how gsync works below its min cap. While freesync just turns into vsync.
However gsync is known to flicker if the fps drops very low, like in loading screens and stuff, while freesync will never flicker.
The max cap vsync isnt an issue for either, as everyone here knows to cap your global fps a few frames below the max refresh on any variable refresh screen.
I keep thinking that these minor defects and differences of gsync/freesync would disappear if we moved from the shit LCD on to some OLED, as oled is good enough to even hold an image @ 0hz, thus making a true fps=hz variable refresh rate possible with a 0-whatever range. Funny that freesync spec minimum is 9hz, while gsync could go as low as 0, according to an interview with Tom Peterson on PC perspective.
Edmond
Postby aeliusg » 22 Mar 2015, 06:27
FreeSync quality will depend on the manufacturers' components of choice. This round they apparently decided to skimp out. So much for 'free'.
aeliusg
Postby applejack » 22 Mar 2015, 16:40
Edmond wrote:However gsync is known to flicker if the fps drops very low, like in loading screens and stuff, while freesync will never flicker.
gsync is known to flicker if the fps drops to 0 specifically. calling that "very low" can be misleading. ;)
applejack
Postby Edmond » 22 Mar 2015, 16:50
Didnt know that its only for exact 0 fps.
Do you have the source where you found that out by any chance?
Edmond
Postby applejack » 23 Mar 2015, 19:06
I read it here:
...we fired up a game that we knew could instantaneously swing from a high FPS (144) to a stalled state (0 FPS) and back again. As it turns out, EVE Online does this exact thing while taking an in-game screen shot...
...Again, this only occurs when games instantaneously drop to 0 FPS, and not when those games dip into low frame rates in a continuous fashion.
http://www.pcper.com/reviews/Editorial/ ... Flickering
however the word "flicker" get tossed around easily, so you could be referring to a possibly noticeable brightness variance (depending on monitor) as the refresh rate doubles / triples and quadruples when the fps dips below 30, so to maintain the widest VRR range possible, as described here:
http://www.pcper.com/reviews/Displays/A ... e-VRR-Wind
applejack
Return to FreeSync
Who is online
Users browsing this forum: No registered users and 1 guest
