Inquiry about variable framerate monitors
Talk about AMD's FreeSync and VESA AdaptiveSync, which are variable refresh rate technologies. They also eliminate stutters, and eliminate tearing.
Postby Vcert » 16 May 2016, 13:22
Hi everyone, not 100% sure this is the correct place to ask this, but im thinking about getting a freesync monitor to hopefully resolve an issue im having.
I notice my games aren't 100% smooth if above the refresh rate(unless it goes way above 120fps), i have thought this is normal, isnt it? Would a freesync monitor solve this? Im currently using a CRT by the way. I wanted to make sure this is related to the monitor before making a big purchase. Vsync seems to get everything super smooth though, so i've been rolling with that in every game.
These are some examples of what im refering to:https://youtu.be/5b9rRInNISA without vsync. https://youtu.be/ocBYfNpwE1Q with it on. And this one https://youtu.be/hADoyh-vXMk capped at 61 for good measure. If i uncap the framerate and it goes above 160fps its practically unnoticeable.
Oh and this screen supports 85hz at 800x600, again with vsync on its perfect, otherwise not so good.
Assuming this is indeed the monitor, is freesync the only option? I ask, because the prices in my country are disgusting when it comes to these type of screens ($700 for an Asus Vg248qe and $1100 for an Acer Xf270h lol).
Any help is most appreciated.
Vcert
Re: Inquiry about variable framerate monitors
Postby lexlazootin » 18 May 2016, 20:46
Yes, this is a common problem for the people that notice it and because you are using a CRT it will stand out a lot more because of the high brightness and low blur.
What GPU do you have? You said that you need a FreeSync monitor but then you linked G-Sync monitor and a FreeSync monitor. Just too make sure you need a Gsync monitor if you have a Nvidia and a FreeSync monitor if you have AMD.
lexlazootin
Postby Sparky » 18 May 2016, 22:17
lexlazootin wrote:Yes, this is a common problem for the people that notice it and because you are using a CRT it will stand out a lot more because of the high brightness and low blur.
Also check to make sure the specific GPU supports it, GCN 1.1 or better for AMD, Kepler or later for Nvidia.
Sparky
Postby Vcert » 18 May 2016, 23:23
Thanks for replying, i have an r7 360. I think it supports freesync, and if it doesnt i hope a 144hz would make it better.
Interesting about the lack of blur on the crt, makes sense. I also notice a lot of screen tearing while in fullscreen, so yeah, definitely gonna have to change this monitor.
Vcert
Return to FreeSync
Who is online
Users browsing this forum: No registered users and 1 guest
