Hi,
since i changed my monitor + pc and im not able to achieve positive sync in ufo test and the other one from your site.
My setup:
13600kf, 32gb ram ddr5
4070ti
Acer Predator XB273u (270hz @10bit, 1440p), xb273uzbmiipruzx
Windows 11 Pro
Here are some screenshots from https://www.testufo.com/animation-time-graph
Im on maximum perfomance windows power plan.
Edit: some more screenshots after disabling MSI Afterburner.
UFO Test VSYNC Failure [Culprit: MSI Afterburner overlay + mouse drivers]
- Zrzut ekranu 2023-04-03 223759.png (233.13 KiB) Viewed 6115 times
- Zrzut ekranu 2023-04-03 222737.png (236.52 KiB) Viewed 6119 times
- Zrzut ekranu 2023-04-03 222655.png (236.74 KiB) Viewed 6119 times
Managed to get it.
MSI Afterburner power draw overlay + mouse drivers.
Fantastic -- thank you for coming back to these forums and reporting on the exact problem!
I've edited the topic title to alert others.
Re: UFO Test VSYNC Failure [Culprit: MSI Afterburner overlay + mouse drivers]
No problem. Thank you for the effort you put into creating this forum.Chief Blur Buster wrote: ↑17 May 2023, 19:50Fantastic -- thank you for coming back to these forums and reporting on the exact problem!
If it helps someone - the CPU power draw makes VSYNC test a failure.
It's fine with the rest of the overlay (gpu power draw, ram usage and other settings) but somehow CPU power draw makes some lag.
