PlayStation4 UFO Test Compatibility
Posted: 12 Jan 2016, 10:21
by redbull2k
Will the UFO test ever be compatible with PS4 Browser? i would like to see how my monitor (benq xl2720z) performs on my ps4, it reports unsupported browser.
Re: UFO Test Compatibility
Posted: 12 Jan 2016, 10:59
by RealNC
It performs the same as with a PC running at 60Hz.
Monitors do not perform differently according to what you connect them to.
Posted: 12 Jan 2016, 11:30
by redbull2k
i have UNSUPPORTED: Generic Webkit cant directly access VSYNC. Does this have any effect?
Posted: 12 Jan 2016, 12:00
by RealNC
redbull2k wrote:i have UNSUPPORTED: Generic Webkit cant directly access VSYNC. Does this have any effect?
For tests that are reporting stats or need exact frame timing, yes. For ghosting and such, no, since you use your eyes for those
Posted: 13 Jan 2016, 04:02
by redbull2k
Should testufo be performed on single strobe or double? It just does not look right and im looking at it with single strobe. I am not sure if the problem is what i think it should look like, to what I am getting. Maybe one of you guys could look on your PS4.
Posted: 13 Jan 2016, 07:58
by lexlazootin
You perform them how ever you want to perform them. Or preferably perform them how you will be using the monitor.
Posted: 22 Jan 2017, 13:50
Unsupported browsers are done by useragent detection.
Supported browsers are listed at:
http://www.testufo.com/browser.html
Your PS4 browser may actually be supported (but at 60Hz). As long as it is 100% stutter-free and runs properly at the refresh rate you want to test it, then it can be usable. Please test
http://www.testufo.com/photo -- does it run 100% perfectly smoothly without stutters?
If you have PS4, please go to
http://www.testufo.com/browser.html and copy-paste the info at the bottom of the screen:
Browser User Agent Info wrote:User Agent:
Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/55.0.2883.87 Safari/537.36
Posted: 04 Nov 2019, 07:46
by oldmanstilltrying
Chief Blur Buster wrote:Unsupported browsers are done by useragent detection.
under browser screen the PS4 shows error: Error loading test: browser
on the photo screen it runs smooth for about 3-4 seconds and then a 1/2 second or so pause.
on the UFO screen it runs in the 40's on the top line, the 20's mid line and the teens lowest line.
Does this info mean the PS4 is not giving accurate data for this web page ?
Re: PlayStation4 UFO Test Compatibility
Posted: 05 Nov 2019, 09:35
ok have some more data:
The ps4 slim gives the following results on the ufo test :
60 FPS line - runs un the high 40's sometimes a 50 never displays 60 fps in the counter
30 FPS line - runs in the 20's never displays 30 FPS
15 FPS line - runs around 10/11 never displays 15
I also have a much older PS4 and a ps4 pro
They both display 60/30/15 appropriately. Is the slim possibly defective ?
