Im getting the Dell S2522HG today, but I’m kinda regretting it..
There's no Viewsonic XG2431 in the UK.
What would you guys recommend ?(240hz and above)25inch max.
I play mostly CS:GO and I watch movies/series ocassionally, but CS GO performances is more important to me.
And Id like IPS panel with any Black strobbing option.
My budget is till 400£
Monitor recommendation
Re: Monitor recommendation
XL2546K. maybe on the second hand market. Lots of people are updrading them now to the XL2566K
| Now: ASUS PG248QP 540Hz. | Past : VG259QM with the Qisda panel/PG27AQN/XL2566K
I dont want TN panels.daviddave1 wrote: ↑08 Nov 2022, 10:05XL2546K. maybe on the second hand market. Lots of people are updrading them now to the XL2566K
then i would go with the acer 390hzFallen12 wrote: ↑08 Nov 2022, 11:03I dont want TN panels.daviddave1 wrote: ↑08 Nov 2022, 10:05XL2546K. maybe on the second hand market. Lots of people are updrading them now to the XL2566K
daviddave1 wrote: ↑08 Nov 2022, 12:24then i would go with the acer 390hzFallen12 wrote: ↑08 Nov 2022, 11:03I dont want TN panels.daviddave1 wrote: ↑08 Nov 2022, 10:05XL2546K. maybe on the second hand market. Lots of people are updrading them now to the XL2566K
Whats the exact model?
Can I ask why? I have a 240 Hz TN monitor and a 390 Hz IPS monitor. I vastly prefer the look and feel of the TN panel but ultimately use the 390 Hz IPS for the faster refresh rate and lower latency. I would definitely go with the Zowie XL2566K in your position. Or you could go for the new ASUS PG27AQN 1440p 27" monitor as it is BY FAR the best performing IPS panel out with response times that finally rival fast TN panels. You could use it in the 25" mode.
i9 9900k | RTX 2080 Ti | 32 GB 4x8GB B-Die 3600 MT/s CL16 | XV252QF 390 Hz 1080p | AW2518H 240 Hz 1080p | PG279Q 144 Hz 1440p
Razer Viper 8K | Artisan Zero Mid XL | Apex Pro TKL | 1 gbps FiOS (Fiber)
his budget is 400 euro.lizardpeter wrote: ↑08 Nov 2022, 13:26Can I ask why? I have a 240 Hz TN monitor and a 390 Hz IPS monitor. I vastly prefer the look and feel of the TN panel but ultimately use the 390 Hz IPS for the faster refresh rate and lower latency. I would definitely go with the Zowie XL2566K in your position. Or you could go for the new ASUS PG27AQN 1440p 27" monitor as it is BY FAR the best performing IPS panel out with response times that finally rival fast TN panels. You could use it in the 25" mode.
I've heard a lot of people say that with TN panels they have more trouble seeing enemies because of the lower color gamut, especially in battle royales like Warzone. Since you have an IPS and a TN panel, is that true?lizardpeter wrote: ↑08 Nov 2022, 13:26Can I ask why? I have a 240 Hz TN monitor and a 390 Hz IPS monitor. I vastly prefer the look and feel of the TN panel but ultimately use the 390 Hz IPS for the faster refresh rate and lower latency. I would definitely go with the Zowie XL2566K in your position. Or you could go for the new ASUS PG27AQN 1440p 27" monitor as it is BY FAR the best performing IPS panel out with response times that finally rival fast TN panels. You could use it in the 25" mode.
In my own experience I would definitely say that's not true. I do not think it's easier to see enemies on IPS. It is, however, certainly easier to see them on 1440p screens (I have one of those too).
