Hello,
i finally found the non-curved VA panel and it's 27" 1440p like i wanted, but it's 240hz.
My PC is meant for games, from 2012 to 2022, all types from point & clicks to FPS, even 2D, and some rare are locked at 60hz.
I set always all to 120hz because i prefer image quality and often use DSR/DSDSR to annihilate aliasing, also why 144/165/1xx. it's not a round number :p
How will behave this 240hz monitor at 120hz ? Thay's the question !.. I will rarely be able to handle games at higher rate than 120 :
4070ti
7800X3D (soon)
B650E-E (soon)
2x16 Furry R. 6000/32
About AG275QZN (BFI)
4070-TI (PNY) // B650E-E (Strix) // 7800X3D (AMD) // 2x16 FURY-R. 6000-32 (Kingston)
Re: About AG275QZN
IPS vs VA version in the dark (removed images)
Re: About AG275QZN
From the interest taken in this monitor and not beeing tested reviewed anywhere should i undersand it's out of a full crap and untrustable to be good ?
Re: About AG275QZN
There are reviews of that monitor on youtube. Just like other flat VAs, it has a slow response time. If that doesn't bother you, everything else about that monitor is ok.
There is no need to limit the monitor to 120Hz on adaptive sync monitors. Just make sure to use a DisplayPort cable, set the monitor to its maximum refresh rate(240Hz), enabled G-sync in the nvidia control panel, and then set a global fps limit of 237 fps.
I also suggest using the medium overdrive in the monitor OSD. it's the best overdrive on that monitor.
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
Re: About AG275QZN
Great one, it's since yesterday i have it, and it's better in every way to my previous too big too 32GN600-B (VA).
A new sight on all my games :p
Thanks, i did how you said i should.
Re: About AG275QZN
It's about BFI, a question more appropriate to the BB forums.
It's a BFI that lets choose between 20 values going lighter or darker from 1 to 20 (0 is off), it's AOC, any knowledge about it here ?
Re: About AG275QZN
https://youtu.be/xKnNCfqX5sE?t=199
According to this review, the highest overdrive setting at 240hz seems to have a ton of overshoot (typical of VA).
So you got two options:
1.) Highest refresh rate, no BFI
In this mode, as the comments above have mentioned, you should use the 2nd OD setting to avoid black smearing.
2.) Best response times possible
You could attempt finding out what the max refresh rate is before you start seeing smearing on highest OD setting (probably 120hz-165hz)
This would result in a overall more responsive experience and perhaps a bit more clarity than the above option
3.) Strobing
If you are able to use MBR on 120hz (some monitors lock MBR to max refresh rate only), most definitely considering doing the QFT trick and enable MBR at whatever option results in the best motion clarity with least amount of crosstalk. (note, use highest OD setting for this hypothetical scenario)
If you cannot run MBR at <240hz, then it's not worth considering BFI imo.
viewtopic.php?t=10402
This article will detail how to use CRU's Vertical Total Calculator if your panel supports MBR at 120hz (or if you want a lagless 120hz mode, which could be preferred as response times would drastically improve and smearingcould/shouldbe close to non-existant on highest OD setting at 120hz)
Re: About AG275QZN
Well, that's complicated, FSync ON/OFF with OD medium, will be what i use globally.kyube wrote: ↑16 Mar 2023, 12:45
1°) 240hz with Freesync ON/OFF on medium overdrive, OKay.
2°) BFI is better when used at 120/165hz,.. that's what it means ? Highest OD setting darkens screen when selected, others don't.
I've not the impression i can make any difference, this monitor looks to have good motion clarity.
Game used was PRODEUS.
3.) Strobing
I was reading TechPowerUp's VA topic and found about QFT right before reading here, so, i'd look at it more seriously for 120hz (it works 120hz MBR, pics attached, set to 1>20 range available too ).
BFI's disabled by OSD if OD's set to highest (called BOOST btw), but others work.
MBR enabled right now (Fsync must disable), monitor is at 240hz (desktop) set to 1 it's lighty, 20 is darker, 10 looks correct.
Set to 120hz, MBR's fully working (all hz except 60 work, at 60hz OSD disables/grays OD setting).
Will look at it.
About BFI, i will try to handle it correctly (set QFT-CRU), i could see some difference in PRODEUS at different settings, but i will have to take notes and be sure of what i see too :p
TYVM.
- 31.jpg (1.68 MiB) Viewed 1849 times
Re: About AG275QZN
The best way to judge motion performance would be to use https://testufo.com/ghosting if talking about non-strobed scenarios or https://testufo.com/crosstalk when talking about strobed scenarios (to judge severity of crosstalk)Klemc wrote: ↑17 Mar 2023, 06:47Well, that's complicated, FSync ON/OFF with OD medium, will be what i use globally.kyube wrote: ↑16 Mar 2023, 12:45
3.) Strobing
Will look at it.
TYVM.
The most important thing for strobing is that you are supposed to run the game at fps = refresh rate with no hitches. It can be quite cumbersome to make this happen in modern games (and strobing is somewhat of a bandaid for the way we perceive motion on displays) especially as the refresh rates increase.
As you've mentioned, VRR/Freesync On or Off (depending on preference) with OD Medium is the easiest and fastest way to setup the monitor without fiddling with QFT.
Re: About AG275QZN (BFI)
I need this tests to be available offline, this PC is not near any internet connection, it's offline !!
I want to do all tests i can and report here the results, it's a monitor that RTINGS wanted to test but it's not sold in USA bc /EU part.
If not available offline, i'll have to plug the monitor in my DeskMini X300 that works with an APU 4650G-Pro.
EDIT :
OKay, it's connected to DeskMini
EDIT2 :
STUTTER WARNING:
Browser stutter detected (1+). Close other apps and tabs
Well, that is bc 240hz on iGPU (APU), but not advertised at 120hz ;(
https://www.aperturegrille.com/software/
Offline equivalents :p
EDIT :
EDIT2 :
STUTTER WARNING:
