Hi
I have an Acer gaming monitor. I use 90 % brightness and did the backlight bleed test. Is this too much backlight bleed?
- IMG_20231223_153339.jpg (1.82 MiB) Viewed 4064 times
- IMG_20231223_153346.jpg (1.91 MiB) Viewed 4064 times
- IMG_20231223_153348.jpg (2.15 MiB) Viewed 4064 times
Re: Is this too much backlight bleed?
It only matters what's actually visible in real life when you set brightness to 100-120cdm2, not 400cdm2.
[phpbb-automod-form: r0ach, please see forum rules, especially the NO POLITICS forum rule.]
This is pretty excessive in my opinion. Note that the orange-ish spots are not backlight bleed, but IPS glow, and it's normal for this panel technology. However, the fainter and more blue-ish spots are indeed backlight bleed. It's a panel lottery, really. I used to play the panel lottery game, but eventually I switched to OLED and I'll never go back to the severely flawed LCD technology.
Main display (TV/PC monitor): LG 42C21LA (4K 120 Hz OLED / WBE panel)
Tested displays: ASUS VG259QM/VG279QM [favourite LCD FPS display] (280 Hz IPS) • Zowie XL2546K/XL2540K/XL2546 (240 Hz TN DyAc) • Dell S3222DGM [favourite LCD display for the best blacks, contrast and panel uniformity] (165 Hz VA) • Dell Alienware AW2521HFLA (240 Hz IPS) • HP Omen X 25f (240 Hz TN) • MSI MAG251RX (240 Hz IPS) • Gigabyte M27Q (170 Hz IPS) • Acer Predator XB273X (240 Hz IPS G-SYNC) • Acer Predator XB271HU (165 Hz IPS G-SYNC) • Acer Nitro XV272UKV (170 Hz IPS) • Acer Nitro XV252QF (390 Hz IPS) • LG 27GN800 (144 Hz IPS) • LG 27GL850 (144 Hz nanoIPS) • LG 27GP850 (180 Hz nanoIPS) • Samsung Odyssey G7 (240 Hz VA)
OS: Windows 11 Pro GPU: Palit GeForce RTX 4090 GameRock OC CPU: AMD Ryzen 7 7800X3D + be quiet! Dark Rock Pro 4 + Arctic MX-6 RAM: 32GB (2x16GB dual channel) DDR5 Kingston Fury Beast Black 6000 MHz CL30 (fully optimized primary and secondary timings by Buildzoid for SK Hynix die on AM5 platform) PSU: Corsair RM1200x SHIFT 1200W (ATX 3.0, PCIe 5.0 12VHPWR 600W) SSD1: Kingston KC3000 1TB NVMe PCIe 4.0 x4 SSD2: Corsair Force MP510 960GB PCIe 3.0 x4 MB: ASUS ROG STRIX X670E-A GAMING WIFI (GPU PCIe 5.0 x16, NVMe PCIe 5.0 x4) CASE: be quiet! Silent Base 802 Window White CASE FANS: be quiet! Silent Wings 4 140mm PWM (3x front, 1x rear, 1x top rear, positive pressure) MOUSE: Logitech G PRO X Superlight (white) Lightspeed wireless MOUSEPAD: ARTISAN FX HIEN (wine red, soft, XL) KEYBOARD: Logitech G915 TKL (white, GL Tactile) Lightspeed wireless HEADPHONES: Sennheiser Momentum 4 Wireless (white) 24-bit 96 KHz + Sennheiser BTD600 Bluetooth 5.2 aptX Adaptive CHAIR: Herman Miller Aeron (graphite, fully loaded, size C)
Ok i did another try. Is this too much backlight bleed?
- IMG_20231229_233007.jpg (2.03 MiB) Viewed 1051 times
- IMG_20231229_232959.jpg (2.08 MiB) Viewed 1051 times
- IMG_20231229_233121.jpg (3.38 MiB) Viewed 1051 times
In my opinion, yes.
