Hello;
I've been tested 4 different monitor and every monitor have this situation idk what is this problem. I sent monitors warranty and they approved cashback. Now ı am using Philips Evnia 25M2N3200W/00 and the other monitors are ı've tested Benq XL2546 ASUS TUF VG259QM and VIEWSONIC XG2431. It's Gpu sutiation or something? or this monitors broken or something.
4 Different monitor same weird results on frameskip test
- IMG-20240326-WA0003.jpg (138.19 KiB) Viewed 1364 times
- IMG-20240326-WA0002.jpg (131.81 KiB) Viewed 1364 times
- IMG-20240326-WA0001.jpg (130.16 KiB) Viewed 1364 times
Re: 4 Different monitor same weird results on frameskip test
If a whole rectangle isn't completely dark, then there is no frame skipping. What you're seeing is most probably an issue with your video camera, not the display. Try a different camera.
(Also, moved thread to correct forum section.)
Thanks ı am new user sorry for this.
ı don't have a camera using my phones camera u saying this camera problem but ı tried same camera on xg2431 ı get same results with pure xp on but ı tried turn off pure xp there's no broken frames anymore. mostly ı play competitive games if frames broken like this peek's are weird and my bullets are disappearing i didn't understand this situation. I try this in offline maps on cs gpu causes lagging or something maybe ?
Pure XP is a backlight strobing method. It flickers the backlight. It can result in camera artifacts, like the one you're seeing. It's not a display issue, it's a camera issue.Reaxein wrote: ↑27 Mar 2024, 07:04ı don't have a camera using my phones camera u saying this camera problem but ı tried same camera on xg2431 ı get same results with pure xp on but ı tried turn off pure xp there's no broken frames anymore. mostly ı play competitive games if frames broken like this peek's are weird and my bullets are disappearing i didn't understand this situation. I try this in offline maps on cs gpu causes lagging or something maybe ?
This is how strobing looks like in slow motion:
https://www.youtube.com/watch?v=GsC9IGmdAvM
When you take a picture with a camera, the camera will sometimes capture the screen while the backlight is off, thus some parts will appear black.
