Disable or Detect DSC?
KarmaCase
Post by KarmaCase » 28 Mar 2024, 00:48
Anyone know if there is a way to disable DSC on your monitor or at least detect whether it's enabled or not? I've been having some strange issues that I think are related to DSC, but I can't even troubleshoot it because I can't be sure whether it's even enabled or not or how to disable it. Any help is greatly appreciated.
Re: Disable or Detect DSC?
Post by RealNC » 28 Mar 2024, 07:10
KarmaCase wrote:
28 Mar 2024, 00:48
Does the monitor allow you to choose the DisplayPort version? If you set it to 1.2, DSC should be disabled and you won't be able to select the maximum refresh rate at the highest possible resolution anymore.
What GPU are you using? If it's Nvidia, you can tell that DSC is used if you can't use DLDSR or NIS.
hart
Post by hart » 28 Mar 2024, 08:49
to disable DSC, the monitor must support the option
to know if is enabled or know, you just look at the connection you are using and the bandwidth you are requiring from the gpu
DP 1.4? 240hz 8bit, 10 bit will use DSC
hdmi 2.1, 315hz on 10 bit, more will use DSC
RealNC wrote:
28 Mar 2024, 07:10
not always true, for example the PG27AQDM let the user use DLDSR with DSC enabled at 240 10bit while other monitors with the same panel can't do it.
Kyouki
Post by Kyouki » 28 Mar 2024, 09:35
RealNC wrote:
28 Mar 2024, 07:10
Unless you select DLDSR from the desktop and then start the game to still have all of the goodies like Gsync which also refuses to work by then.
[At least I think that was DSC related...]
RatchetStrap
Post by RatchetStrap » 04 Apr 2024, 05:08
I've been trying to find a way for a while now too. My monitor allows you to disable DSC for DP, but not for HDMI. Well, the HDMI port is full bandwidth 2.1, 48Gpbs. Which should support my 1440P 240Hz monitor without DSC. I assume it's off, but if it's not, I may as well use DP.
Thankfully my panel supports GSync over HDMI and DP so everything works even if DSC is active.
The DLDSR trick doesn't work all the time. https://tftcentral.co.uk/news/nvidia-ds ... -sometimes
I can use DLDSR when DSC is active with my combo. A 4070FE with a LG 27GR83Q-B, at 1440P 240Hz and 10bit color with HDR active, no issues.
To troubleshoot your issue, try 60Hz. DSC should be negotiated in the handshake only when necessary.
