Pointers for XL2546K & 60 FPS Locked Games.
Domyo
Post by Domyo » 17 Apr 2024, 00:52
Hey guys, I'm just wondering how I should approach setting up my monitor to be used with games such as Tekken 8 which are locked at 60fps
Would it be wise to lower from 240hz to 60/120hz for a more seamless experience, or would the Situation of keeping it on 239.760hz and using Freesync & AMA to High be the way to go?
(I did try using Toasty's Vertical Calculator to try QFT for 60hz but I keep getting a black Screen) Much Appreciated!
Re: Pointers for XL2546K & 60 FPS Locked Games.
Post by RealNC » 18 Apr 2024, 06:29
Freesync is always better if it works for that game and your display is good at VRR.
Supermodel_Evelynn
Post by Supermodel_Evelynn » 21 Apr 2024, 21:20
If you are not using strobing then just leave it set to max Refresh rate.
Strobing requires a fixed refresh rate, these BenQ monitors do NOT support 60 hz strobing it has a lot of cross talk unplayable.
You can however set it to 120 HZ and use the Tekken 8 FPS Unlocker it will also do 240 FPS if you have a RTX 4090 that is.
And there is also Lossless_Scaling App on steam which will run any fighting game at 120 FPS interpolated.
60HZ has nasty blur without strobing I much prefer 120 FPS mode FPS unlocked
