Does Supersampling a Game Improve Motion Clarity With Low Persistence Displays?
Posted: 22 Apr 2024, 02:29
by jman54
I was messing with an hdcrt, a super fine pitch Sony, and I noticed that it seemed like the motion quality was ever so slightly improved when downscaling from 4k and even from 8k. Finding a game to actually work at 1080i was challenging but I found Dead or Alive 5 was able to so I am certain it isn't something to do with scaling problems. The static image differences were nonexistent outside of distant vegetation when comparing 4k vs 8k but the sharpness difference of the background while spinning in circles seemed noticeable to me, albeit extremely small.
Re: Does Supersampling a Game Improve Motion Clarity With Low Persistence Displays?
Posted: 22 Apr 2024, 11:11
by Supermodel_Evelynn
super sampling improves anti aliasing it's how AA was designed back in the days , this is the Original Anti Aliasing method so yes it improves motion clarity in the sense there is no more jaggies.
I mean it removes jaggies without introducing the nasty blur of TAA
Posted: 13 May 2024, 09:18
by daemonjax
Not sure what you mean by motion clarity, but downscaling will produce a less aliased image. At least, potentially. I mean, you CAN oversharpen a smooth image and produce aliasing.
Personally, I like some motion blur to help smooth out frametime variance. If a game doesn't have ingame motion blur, then sometimes I need to reduce my lcd's response times to add some ghosting to make it feel buttery smooth.
Posted: 26 May 2024, 23:10
by virusfemale
Hello, this is the Original Anti Aliasing technique. To answer your question, the motion clarity is improved since jaggies are eliminated. For me, motion blur works well to reduce frametime variance.
