The giveaway was valid only until February 28th, 2015Chief Blur Buster wrote:UPDATE: Giveaway has ended.
This is the winner announcement
Please pay attention to Blur Busters for the next monitor giveaway, which will likely be one of our GSYNC monitors
Forum Registrations are working now!
Earlier, an overeager spamfilter was blocking everyone from registering for several days.
As an apology for the inconvenience of the beserk spamfilter,
I'm going to give away one of the 144Hz monitors that I own.
Free 120Hz+ LightBoost Monitor Prize
For a Randomly Selected Newly Registered Forum Member
A BENQ XL2411T Gaming Monitor (value: $250) will be given away to a newly registered forum member (5 posts).
RULES:
(1) Register! You are newly registered between January 26th, 2015 through February 28th, 2015, inclusive (Greenwich Mean Time)
(2) You must make a minimum of 5 forum posts by Febraury 28th, that are deemed legitimate posts (at Moderator's discretion)
(3) A randomly selected newly registered new forum member, meeting (1) and (2) will be chosen.
(4) The website http://www.random.org will be used to select the forum member number between forum member #1424 through the last registered forum member right up to the final final second (23:59:59) Greenwich Mean Time on February 28th, 2015.
(5) Monitor is currently sitting in Chief Blur Buster's Lab. It will be packed into its original box, with DVI and power cables.
(6) Giveaway is valid in United States, Canada, Europe, United Kingdom, Ireland, New Zealand, and Australia.
(7) One registration per person. No multiple registrations.
(8) If you are randomly selected, you will first be asked a skill testing question (by PM & by email) before the monitor is awarded.
(I know, I know -- this rule may sound silly -- but the Legal Beagles needs it!)
This BENQ XL2411T gaming monitor is 100% compatible with ToastyX Strobelight, for easy LightBoost operation.
