(SOLVED)Need 3d Vision EDID OVERRIDE(HDMI)
Dirtydeedz
Post by Dirtydeedz » 16 Mar 2015, 12:27
Hey my first post!
I'm trying to get nVidia 3D Vision working on a Seiki se39uy04(modified firmware). I have it working, but, the glasses are out of sync. R & L eyes are opposite. I've been using EDID overrides that were created when the monitors were hooked up to the PC using DualLink DVI cables; and, I think this is what is throwing the glasses out of sync.
Does anyone know where to edit the "Connection" in a EDID dump? I have an editor. I just don't know which value to change (from DVI to HDMI).
or
If anyone here can point me to a downloadable EDID dump(using HDMI) or would be so generous to create a EDID dump while using HDMI, I would greatly appreciate it. The following list are the monitor edid's I'm looking for. They are all HDMI 1.4a Certified.
Acer GN245HQ , Acer GN246HL, Acer HN274H , ASUS VG278H, BenQ XL2420TX, ViewSonic V3D245
***(SOLUTION) Using either ToastyX CRU (Extened Display Options) or Monitor Asset Manager(File/Edit).
