Just looking for a solution. My monitor is an ASUS VS238 via HDMI.
I'll be playing in a game for about 5 minutes, then my screen goes black and a message pops up saying 'Out of Range' on my monitor. It seems to have began after I updated my graphics drivers, but I have since rolled them back and am still experiencing the problem. I also fiddeled with the cs:go configs for theatre mode before the problem arose, but I have since deleted them all and redownloaded them via verifying game cache on steam. I literally cannot play and I am sadpanda.
Fixes I've tried:
Rollback driver
Reinstall cs:go
Reduce screen resolution
Update monitor drivers (Generic PnP drivers, no other found)
Change monitor refresh rate
Run in windowed mode and borderless window
Turn off anti-aliasing
Delete configs and verify via steam
Use DVI
Uninstalled nVidia bloatware
I'm sure I am forgetting a couple of things I've tried but I'll add them if I remember them.
Specs:
i5-4670K @ 3.4GHz
8.00 GB RAM
nVidia GTX 770
Windows 8.1 64-bit
Monitor 'Out of Range'? Need some technical support, don't k
Post by Knovocaine » 08 Apr 2015, 22:49
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
