Hi guys,
I upgraded to windows 10 yesterday and it somehow removed my Display scaling from Nvidia. I use it to stretch my CS:GO res. Is there any way I can get this back?
Thanks.
Display scaling on Windows 10
Re: Display scaling on Windows 10
Hi I had the same problem. I believe I had to download the nvidia driver update from the website and it fixed the display scaling.
http://www.nvidia.com/Download/index.aspx?lang=en-us
Also if that doesn't work try ticking the "override the scaling mode set by games" box in the nvidia control panel (which is in the adjust desktop size and position tab).
Already tried that but I fixed it with this: https://www.reddit.com/r/GlobalOffensiv ... _of_input/rkgzen wrote:Hi I had the same problem. I believe I had to download the nvidia driver update from the website and it fixed the display scaling.
Works fine now.
Thanks man! I've been wondering why I've been having input lag.
