phase setting not stored?
Posted: 16 Dec 2015, 11:21
Can you please help me with the following problem? The beamer started to set wrong phase, as a result the image becomes blurry.
Details are here: the beamer is BENQ MX710. Initially I set the phase on the beamer to the best setting for my computer: phase=6. The beamer remembered it and set it correctly every time when I switch off/on the beamer or the computer. One month everything was OK. Suddenly it starts to set phase=16. After manual change to phase=6 it switches back to phase=16. This happens every time when the beamer or computer is switched off/on, signal source is switched between computer and TV, other user is logged in on computer etc. Is it possible to set the phase permanently, so I should not adjust it every time when I switch the beamer to the computer? Thank you.
