Why are you acting like a child?illetyus wrote:I am not satisfied man... Should i buy Dell U2414H and sell this monitor?...Sparky wrote:Lowering your refresh rate can only increase lag, if you want a stable framerate, use a framerate cap. Preferably in game.
Doesn't matter what monitor you have.
You set 60hz, you're going to lag. Period.
I'll say it 1 more time:
THIS IS A FUNCTION OF THE VIDEO CARD.
THE MONITOR JUST DISPLAYS IMAGES. IT DOESNT LAG.
the *ONLY* Extra lag you will get from the monitor is if you are using BLUR REDUCTION at 60hz with SINGLE STROBE=ON, without a vertical total tweak. You didn't mention any of this in your post. You just cried about lag.
if you're lagging and trying to use blur reduction at 60hz (with Single Strobe set to "on" in the Benq service menu), set the Strobe Phase to 100. This will improve input lag by 1 frame compared to Strobe phase 000 (16.7ms improvement).
Some monitors have processing lag, true, but the XL Z series monitors have among the lowest processing lag in the market. The XL2720Z was tested as having only 2-3ms of processing lag. The XL2411Z uses the exact same scalar as the XL2720Z (Mstar 8556T), so its not the monitor causing it.
you need to look elsewhere. And I already told you everything and you completely, totally IGNORED everything I said.
1) turn off vsync.
2) set prerender limit to "1" in your favorite Nvidia card tweaking utility. I do not know if the Nvidia control panel allows setting "Max frames allowed (same thing) or "max frames ahead". If it does, then good. Use it. if not, use a tweaking utility.
I don't own an Nvidia card. Can't tell you what to use.
3) if you're still to complain about input lag, either sell your GTX 1070 and get an AMD card, or sell your computer and buy a console. Your XL2411Z has a "single strobe" setting for 60hz gaming on a console. Works well.
